IF Then Formula with Yes/No parameters reporting text
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
435 Aufrufe, 2 Antworten
I need some help! I am trying to make an IF THEN formula and everything looks right, but I keep getting the Bad IF-Statement format error. I think the problem is with the Nested Formula formatting.
I am trying to state the following:
  1. If FinEnd_Side_l is clicked then I want this parameter to report an "L"
  2. If FinEnd_Side_ll is clicked then I want this parameter to report an "R"
  3. If both FinEnd_Side l and FinEnd_Side ll are clicked I want this parameter to report a "B"
  4. If neither are clicked this parameter can remain empty.
Here is the formula I have written which gives the error:
if((and(FinEnd_Side_l, (not(FinEnd_Side_ll)))), "L", " ", if((and(FinEnd_Side_ll, (not(FinEnd_Side_l)))), "R", " ", if((and(FinEnd_Side_ll, FinEnd_Side_l)), "B", " ", if((not(FinEnd_Side_ll, FinEnd_Side_l)), " ", " " ))))
Can anyone help?
Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: Anonymous
This should do it.
if(and(FinEnd_Side_l, FinEnd_Side_ll), "B", if(FinEnd_Side_l, "L", if(FinEnd_Side_ll, "R", "")))
You do not have to keep checking with all the and/nots. If a true is found then the formula stops and comes with the result.
Because I already checked if both are true then I only have to look if one is true to come to a conclusion if it should be L or R. I often build these formulas in something like notepad. You have a better overview of your longer formulas
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
als Antwort auf: L.Maas
Thank you. Your response is very appreciated.
