Hi Everyone,
I've been having some troubles writing what I thought would be a simple formula to control the visibility parameter based on the dimensional parameter that I've already got in place.
Basically, I wish for the visibility to remain on unless the glazing offset is greater than 175mm. so this is how I have tried to formulate this -
if(Glazing Offset, 175 mm, Standard Glazing, 1 < 2, 1 < 0)
If somebody could point out where i am going wrong that would be greatly appreciated.
Gelöst! Gehe zur Lösung
Gelöst von bin. Gehe zur Lösung
You need to use your if statement correctly; IF , THEN , ELSE
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
IF (Length < 3000mm , 200mm , 300mm )
too many statements here; if(Glazing Offset , 175 mm , Standard Glazing , 1 < 2 , 1 < 0 )
Thanks for this, hopefully over time I will get a better grasp of how to construct the statements.
