I have a door family with a nested hardware family and I'd like to change the visibility of the plan view depending on which hardware family is selected. (basically, a ball catch door would show at 45 degrees).
The hardware family is changed by a revit family parameter: Door Hardware Family. If it equals say "Inactive", I'd like to check the Door Hardware (BallCatch) parameter.
see the attached image.
Is this possible?
Thanks for the reply.
What I meant was. I'd like the Hardware (BallCatch) to be ON, only when the Door Hardware Family is set to the family type Kwikset Katara : Inactive/Dummy.
Hopefully the attached will help.
You cannot use the <Family Type> in an IF statement; you will need a second set of parameters (text or integer) in the hardware family before you nest them...then after u nest them into the door, you associate those to similar parameters in the door and u use those to control the yes/no with IF statements
see solution which I posted here ... http://forums.autodesk.com/t5/revit-architecture/formula-lt-family-type-gt-parameter/m-p/6483065#M12...
i have no access to REVIT at the moment, but I will try to check the family u attached as soon as I get to the office ![]()
is Katara still ongoing?
