IF Length parameter
IF Length parameter
mbiAK7WZ
Message 1 of 9
IF Length parameter
mbiAK7WZ
Hello again.
I am currently making a family, and have problems with the IF parameter on the length. I need the paratmeter ''Altan bredde'' to have the length, 3290mm, 3380mm and so on up to 4500mm, but i cant get it to work and looked at many different sites to get to know how it can be done
So far i have tried '' IF(length 3200mm, 3290mm, 3380mm) and IF(Altan bredde 3200mm, 3290mm, 3380mm) and IF(length < 3200mm, 3290mm, 3380mm) and IF(Altan bredde < 3200mm, 3290mm, 3380mm)
I hope you can help
I have link the file here to.
Replies (8)
Message 2 of 9
mbiAK7WZ
The file is attached here
Message 3 of 9
I don't see Length parameter in your family.
Message 4 of 9
mbiAK7WZ
Altan bredde, altan dybde should be length parameter, if i change the dimensions on them it changes the drawing, im far from done with parameters, but i need to get If length parameter on the dimensions i mentioned.
If you have a solution to make the parameter the way you are thinking, then i am open for it
Message 5 of 9
Let's say, if you input the value 3320, do you want the length to become 3290 or 3380?
Message 6 of 9
mbiAK7WZ
Message 7 of 9
Add Length_Input parameter.  Your formula for Altan Bredde should be like this:
if(or(Length_Input<3200,Length_Input=3200), 3200,
if(or(Length_Input>3200,Length_Input<3290,Length_Input=3290),3290,
if(or(Length_Input>3290,Length_Input<3380,Length_Input=3380),3380,
4500)))
The ... is for you to continue to develop until it reaches 4500.
By the way, your family is super heavy.
Message 8 of 9
mbiAK7WZ
 it makes this messege when i put in the parameter
Message 9 of 9
See my revised formula. Yours is missing the last value 4500 so the syntax is incomplete.  copy paste ithe one below to yours.
if(or(Length_Input<3200,Length_Input=3200), 3200,if(or(Length_Input>3200,Length_Input<3290,Length_Input=3290),3290,if(or(Length_Input>3290,Length_Input<3380,Length_Input=3380),3380, 4500)))
