Ideas on how best to handle multiple siding options for model plans using Design Options.
3 ANTWORTEN 3
Nachricht 1 von 4
775cforsyth
380 Aufrufe, 3 Antworten
I have a plan set with two siding options, which will be wood or stucco and I was looking for suggestions on how best to set them up using Design Options.
Initial thought is to paint one siding material onto the walls then model in place the second option in a Design Option. Any ideas or suggestions would be hugely appreciated!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: 775cforsyth
Copy them to different Options and change the type/material.
Create Parts and set Parts to use a different material so Originals is one option and Parts is another.
Nachricht 3 von 4
775cforsyth
als Antwort auf: ToanDN
Interesting idea. I'll give it a try.
Thank you.
Nachricht 4 von 4
A whole Plan Set???  Stucco to Wood, or vice versa???  I wouldn't be doing DOs or Parts.  That's a sh*t-load of work. I'd just copy the Project.  One Stucco; one Wood.  You can always Link.
