Hi all,
I'm working on a high rise apartment project at the moment and there is this balcony glass louvre systems on every apartment runs for 40+ storeys. Please find attached images for reference.
As you can see, I've managed to generate this system with a family that's modelled with 6 vertical columns to have these glass panels to be fixed onto. All of these panels are modelled and draw up one by one.
Now, I need to find out how to make this into a parametric family/curtain wall system so that I can control which one to open/closed/on an angle. The balcony is generally with a 1.2m glass balustrade with a rail at the back, and the upper parts are 6 vertical bays of pivot glass panels that are operated together each bay i.e. if one vertical bay is closed, all of its panels are closed, as opposed to what's showing in the images above (so that it reduces cost/easier to manage, rather than individual panel).
Any thoughts guys?
Also, this is the first time I'm working on high rise towers that needs to repeat itself for tens of times. How I am currently managing it is that I've created a typical floor in one project and grouped it, then paste them onto every floors. However, this group has make Revit very sluggish, esp. when updating one louvre/balcony, etc. Is there a better way to manage it? I also don't like how you can't save an existing group as a new one, as there are floors different to typical floors and I'l' have to paste these unique floors to its level first, then ungroup it, edit, and regroup as a new group. Once I update a typical floor, I'll have to repeat this process again.. which is really frustrating!
I'll need to make an updated model to re-submit for approval in a week's time. Any good tips would be greatly apprecaited!
Cheers guys!
