I would like to add a Material to a Reveal without using the Paint Tool.
2 ANTWORTEN 2
Nachricht 1 von 3
tturnerJBN46
288 Aufrufe, 2 Antworten
I would like to add a Material to a Reveal without using the Paint Tool. I guess it would somehow need to be added to the Profile Family. Not sure if I could use some type of Parameter. I am using Revit 2021 for this Project.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: tturnerJBN46
You can create a line based family with a void to cut the wall and a solid with a material to clad the reveal surfaces.
Nachricht 3 von 3
tturnerJBN46
The only problem I am having is applying a Material. For some reason I don't know the Solid & Void I created are showing up as a Peach color.
