I want to write the modifed time in the family, is there away?
1 ANTWORT 1
Nachricht 1 von 2
5dwith_ggc
214 Aufrufe, 1 Antwort
Is there a way to write the updated date and time as an instance parameter in the wall family?
Tags (1)
Beschriftungen (2)
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: 5dwith_ggc
@5dwith_ggc
Add it to the to category walls either as a project parameter if you just want to schedule or as Shared Parameter if you want to also use in Labels) ...however, you will be entering value manually
