i want to select instances with same properties,
3 ANTWORTEN 3
Nachricht 1 von 4
426 Aufrufe, 3 Antworten
hello
i want to select certain columns with same family, and properties. i know how to use select all instances function. but I it wont limit the search down to the coulmns with same base offset
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Anonymous
hello, you can try temporary hide/isolate (with select all instances) or filter.
Nachricht 3 von 4
als Antwort auf: ennujozlagam
no it did not work.
Nachricht 4 von 4
You can create a schedule, filter or group them per criteria you want, such as the base iffset1, untick itemize every instance, highlight the matching row, and choose highlight in model.
