I want to see the floor plan however its blocked by objects
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
kalktika
479 Aufrufe, 8 Antworten
I want to see the floor plan below the objects how can I  make that possible. I want to see it like in the first picture.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: kalktika
Change the View Range Settings or Hide the obstructing Elements in the View.
About the View Range | Revit 2019 | Autodesk Knowledge Network
Nachricht 3 von 9
kalktika
als Antwort auf: barthbradley
thanks for the answer but which parameter though?
Nachricht 4 von 9
Set the view to Wireframe.
For future reference, when link DWG in for reference, if you tick Current View Only box, then you can toggle the DWG to display in Foreground or Background.  Foreground will send it to front of Revit model and you can see the DWG without changing the View to Wireframe.
Nachricht 5 von 9
Well, if something is obstructing something below it, then you want to lower the Cut Plane to be below the obstruction.
Nachricht 6 von 9
kalktika
als Antwort auf: ToanDN
that doesn't work
Nachricht 7 von 9
Looks like you have a Graphic Override in place. Select Floor and reset Override Graphics in View.  Or just Hide the Element in View.
...I'm assuming that is a Wireframe View.
Nachricht 8 von 9
kalktika
foreground option worked thanks.
Nachricht 9 von 9
CAD!  I missed that part in your description of the problem.  Oh wait! You didn't mention it.
@ToanDN: Nice mind-reading.
