i want to make extrusion by sketchup mass
10 REPLIES 10
Message 1 of 11
ohayanyc
485 Views, 10 Replies
hi
I insert mass in place from sketchup
now I want to make extrusion mass parts
did I have to draw profile of each plane?
how to pick a profile of sketchup mass and make of him extrusion?
10 REPLIES 10
Message 2 of 11
L.Maas
in reply to: ohayanyc
You can create an elevation view perpendicular on the area you want to create the profile which will make it easier to trace.
You can try to use the pick tool to create the profile. Depends little bit on the file you try to trace if the lines can be picked. Not sure if Sketchup will expose the lines to allow this.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 11
alyrashid
there is a difference between both softwares the revit and the sketshup each one works with a different system and this what makes the use of the model done inside sketshup difficult and not editable . the best thing is to draw them again as said @enllnt .
Regards
Architect Aly Rashid,
Autodesk Certified Professional Revit
Autodesk Certified Instructor
If you find my answer is a solution do not hesitate to mark it as a solution so others can benefit from it, and if you find it useful I would like to have a kudos, thank you
Message 4 of 11
ohayanyc
in reply to: alyrashid
INSERT SKETCHUP MASS
MASS A WALL BY PICK A PLANE FROM MASS
HIDE ALL ELEMENT . LEFT THE WALL JUST CREATED
MAKE EXTRUSION
PICK A PLANE FROM THIS WALL
THEN SHOW GRID(NEXT TO SET PLANE)
NOW ITS EASY TO DRAW PROFILE
Message 5 of 11
spkoulis
Just be careful when introducing angles from a non native geometry (SketchUp) to Revit elements like walls and profiles. It is very easy to run into "slightly off axis" problems further down the line. I would introduce reference planes in a manual way making sure angles do not have more than 3 decimal digits in the degrees.
Message 6 of 11
ohayanyc
Hi
I still didnt get how to move extru. Inside plane
Say i want to move extru. At plane x to specific point at plane y
How to do this?
Also i cant move extrus. In same plan to specifoc point. No snaps at all...
Please help
Thanks a lot
Message 7 of 11
Message 8 of 11
ohayanyc
Solved
Thanks alot
Message 9 of 11
alyrashid
you have to work with move tool and remove constraint or unlock plan constraints and try to work on the elevation or section and avoid working on the 3d so u dont lose the axis movement
Regards
Message 10 of 11
ohayanyc
Yes i know i have to avoid sketching in 3d... thanks
Another q. If i want to update sketchup mass and insert it exactylt at same place the former mass was
How to do that?
Message 11 of 11
mpwuzhere
@alyrashid  Working in 3D is one of the things I like best about Revit!  There is nothing wrong with working in it.
@ohayanyc you can work in 3D all you want, just be sure to set your workplane before modifying/creating.
