i want to create a surface made of 4 adaptive points in revit, but i want this surface to offset from those point in Z direction and on X axis or Y axis
OFHACHEM
Message 1 of 25
OFHACHEM
Basically the title says it all, i am creating a 4 points adaptive family where i want the surface to offset from those points in the Z axis and also most importantly outside the border of those points in the Y or X axis, here is a picture explaining exactly the offset.
Z axis offset is easily done and internal offset is easily done, but i want the offset outside the border of those 4 points.
Replies (24)
Message 21 of 25
OFHACHEM
I LOVE YOU. Can you please explain the process ?
@ToanDN
Message 22 of 25
The process is pretty much the same as I said earlier, but you create a line-through-points (to re-orient the ref plane) before adding the next point.
Message 23 of 25
OFHACHEM
So the host is now the ref line plane, if I understood correctly?
thank you @ToanDN @barthbradley  you are both amazing
Message 24 of 25
No.  The host is still on the ref point.  Just the ref points planes are reoriented after you creating the spline from them.
Message 25 of 25
OFHACHEM
Understood. I did not think of that thank you so much for the help
