i want to create a new system floor
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
288 Aufrufe, 2 Antworten
Hello all, i want to create new floor system as shown in the image . instead of two separate floor types. i want to combine concrete floor to one distance and finished floor with membrane  offset to  end of the interior wall or as need . is it possible to create. b'cos i couldn't fine floor family. please advice
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I'm not sure if this is similar to what you require. What I did was create the floor system with all of its components, in this example I have a substrate then finish on top of my concrete slab. I've used the join command to join the wall and floor and used the align tool to dictate where my wall will flush with the floor layer then used Switch Join order. Hope this helps.
If this resolves your issue, please click ACCEPT AS SOLUTION to enhance the forum.
Nachricht 3 von 3
sgoodmansen
Ooh switching join order is a great idea.  Thanks for sharing.
