I want one wall, I see two
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
marco.morazzini86
574 Aufrufe, 9 Antworten
When I create a wall, why does this wall appear split automatically? After a certain length, the wall is considered a single element but this appears divided into 2 with a small empty space between them. I think this should be for a kind of structural joint but, what should I do if I do not need that?
Thanks for your help
Marco
9 ANTWORTEN 9
Nachricht 2 von 10
martijn_pater
als Antwort auf: marco.morazzini86
Share a screenshot. Don't know what you're looking at, possibly a curtain wall... hard to tell.
Nachricht 3 von 10
marco.morazzini86
als Antwort auf: martijn_pater
What you see is generated automatically, although Revit sees it as just one wallCattura.PNG
Nachricht 4 von 10
martijn_pater
Could be caused by intersecting (hidden) geometry, maybe check reveal hidden elements (also check 3d)...
Nachricht 5 von 10
marco.morazzini86
I checked and there is no hidden geometry.
Nachricht 6 von 10
martijn_pater
It could also be intersecting geometry set in a different phase.
Nachricht 7 von 10
There is a wall there in a different phase.
Nachricht 8 von 10
nmarcelis
als Antwort auf: ToanDN
You're spot on, Phasing is often the last thing people check when things are not working like they should or have visibility issues.
Revit Certified Professional Architecture, Structure and MEP.
Nachricht 9 von 10
syman2000
Set the phase filter to none and see if there is object hidden there.
As well click on reveal all to reveal object hidden by element
Nachricht 10 von 10
martijn_pater
als Antwort auf: nmarcelis
Like I said, intersecting geometry in a different phase. It is caused by join behavior over different phases.
FWIW:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
