The x,y, arrows I circled is hidden and out of crop region but when I print the pdf, the pdf includes the x,y object I circled. I can’t move,un hide, or select the object. Is my model bugged?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von Yien_Chao. Gehe zur Lösung
No it is not hidden. Hidden elements would be pink color. Turn off Internal Origin under Site category.
It is pink, look closer at the arrows, also look at my model at the origin icons they're pink as well. That being said I went to visibility prop and unchecked internal origin and I believe that did the trick thanks!
