I receive a location warning trying to generate energy model to optimize in Insight
1 ANTWORT 1
Nachricht 1 von 2
edgar.rey
217 Aufrufe, 1 Antwort
Hi, I am using Revit 2024 and I am trying to send the energy simulation data to Insight. I already created the energy model and when I use the "Generate" button I received this message that says: "Failed to upload model to cloud: Enter an address or the geographic coordinates (latitude and longitude)" (see attached file). I checked in the "Location" button and I find that my project is located in the expected site.
I also used Revit 2023 for this same procedure and everything was working well. I was able to use the "Generate" button without this warning and then I used the "Optimize" button and worked in Insight.
I appreciate for some help related to this issue.
Tags (3)
1 ANTWORT 1
Nachricht 2 von 2
s1171878
als Antwort auf: edgar.rey
