I need help making a cube,
Hey guys i need a very simple cube looking building drawn in revit i made the physical model but i dont know how to draw the building it self in revit.
( well ccomplicated for me 😞 ) If someone could draw that for me i would very much appriciate it since i need to hand in the asingment first thing tomorow morning. Thank you in advance.
 The building is 15*15*15 meters (49'2''*49'2''*49'2'') there are 2 floors in the building excluding the ground floor. The height from floor to cealing is 5 meters (16' 5 '').
The images are as follows : B is merged with D. A connects to D. And than C follow connected with D and B.
The building should just be white, just clear glass on the oppenings or if that is to much trouble than nothing.
I am so sorry to ask like this but i am desperate.
Best of whishes.
12476105_10207050331149314_2111977883_n.jpg12626114_10207050331309318_1890463766_n.jpg12650278_10207050331509323_1481179147_n.jpg12650470_10207050331389320_1735006600_n.jpg12660379_10207050331229316_399437671_n.jpg12674475_10207050331069312_1615314883_n.jpg
dzanta
The easiest way is to create a conceptual mass cube within the revit conceptual massing environment.  Then split it up and push/pull the faces until you get the exact shape you want.  When finished, load into a project as use Roof by Face, Wall by Face, Floor by Face and Curtain System by Face commands to apply Revit building elements onto the face of the mass object.  If the mass object changes down the road, you and update your model accordingly easily.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
