I have picked up this project from an employee who has left.
Does anyone have any idea why these four sheets are out of order? All other sheets are inline. When I uncheck "itemize every instance" both the sheets that are out of order combine and the text switches to "varies" I'm sure that helps find what the issue is but I'm not sure where to go from here.
I'm at a loss. I attached a reference photo if it helps.
Gelöst! Gehe zur Lösung
Gelöst von GaryOrrMBI. Gehe zur Lösung
You are sorting by a Parameter called "Order", not the "Sheet Number". Set that parameter correctly on the affected sheets, or sort by the sheet number that you're seeing and expecting it to sort by.
-G
Thank you for the help. You are correct.
I have not used this feature for ordering sheets before so Ii was glazing over the text area in the properties.
