I'm new at boolean, not quite getting the AND statement to work
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
chris.stroudWUD5J
360 Aufrufe, 4 Antworten
So Heres what i'm trying:
IF <BLOCK VISIBILITY> IS ON/OFF, DO X. IF BOTH <BLOCK VISIBILITY> AND <CORE VISIBILITY> ARE OFF, DO Y
I can get the first part to work just fine, but i'm struggling with the underlined part, I've tried a bunch of ways and got a bunch of different errors, i'm just too new at this sort of thing to understand the correct syntax.
so here's what i'm trying:
the line in core name isn't important for the moment, that works
Does the second part need to be a new line? or am i completely off?
Thank you.
4 ANTWORTEN 4
Nachricht 2 von 5
Alright, i just figured it out.
Turns out the AND statement should have been the answer to the NO part of the first part:
if(BLOCK VISIBILITY, 38 mm, if(and(BLOCK VISIBILITY, CORE VISIBILITY), 38 mm, 4 mm))
:leicht_lächelndes_Gesicht:
Nachricht 3 von 5
Ilic.Andrej
als Antwort auf: chris.stroudWUD5J
I assume you want to do OR statement and you don't know that it exists. Yes, it exists.
if(or(block visibility,core visibility),x,y)
If any one of those is checked, do one thing. Otherwise, do another...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 4 von 5
chris.stroudWUD5J
als Antwort auf: Ilic.Andrej
Hey thank you very much, that'll come in hand for the next thing I need to do :leicht_lächelndes_Gesicht:
Nachricht 5 von 5
bin
Maybe this?
if(and(not(BLOCK VISIBILITY),not(CORE VISIBILITY)),Y,X)
