Hi, when I'm trying to attach my walls to the floor above, I keep on getting the error "Can't keep wall and floor joined". I double checked the walls and it seems to be cutting through the floor and yet I still get this error. How do you fix this? Thank you very much.
hello, have you try to click unjoined elements and see what happen or post here some part files your floor and walls only so we can check. thanks
It's not clear what are you doing when you get this message?
Could you be changing the wall hight so it's not touching the floor?- this could cause them to unjoin.
