I have to get objects without mesh (inner lines) while exporting to dwg from revit
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
2744 Aufrufe, 8 Antworten
please tell me whats the possible way to get exported objects(in dwg) should not contain inner lines(unwanted meshes). Firstly, After imported dwg or 3dm file of model in revit, i extracted 2d and the exported to dwg where i have to delete inner unwanted lines. (imported chair image attached for your reference)
So, please guide me any simple way. Thank you.
8 ANTWORTEN 8
Nachricht 2 von 9
syman2000
als Antwort auf: Anonymous
You need to use 3ds max to hide those extra edge. First you select the edit mesh and then select those mesh and click on invisible.
Then export to DXF or DWG
When you import into Revit, you will see those mesh hidden and only see silhouette.
Nachricht 3 von 9
als Antwort auf: syman2000
@syman2000
Thank you so much for your reply.
I want to know  which type of file format you used in 3ds max?
I am not getting this work done while i do the same.
Nachricht 4 von 9
syman2000
For 3ds max it can be any format - DWG, OBJ, FBX. However when you export to CAD, you have to use DWG/DXF older format to make it work. I use 2004 and it works.
Nachricht 5 von 9
Ok, Thank you so much for your swift reply,
Can i send my model? , can you please do the same as you said and please export in revit & see whether its fine or not
Because, i have tried for many times. But, i am not getting it. I dont know i have rightly followed the steps.
Can you please try and tell me?
I have attached mine with some formats, Thank you in Advance.
And i have searched videos in your you tube channel as well.  i Could not find related video. Please, post that too.
Nachricht 6 von 9
syman2000
See attached.
Nachricht 7 von 9
Thank you very much for your work for me.
Yeah its working now, we used DXF/DWG in 2004 format. But, few elements were missing after exporting to Revit.
So, please send screen capture of how you are doing. We checked most of your videos. We are not able to find this trick in that. Actually, sorry for disturbance.
Can you please send video capture of your work or mention which video of your channel shows this helpful trick.
You have been so kind, Thanks for that. Your remarkable help is very unforgettable.
Nachricht 8 von 9
syman2000
Here is a quick video I did. Hopefully it will be useful for you.
https://youtu.be/F7Z4qT8S29s
Nachricht 9 von 9
Thank you so much for your valuable work that helped me a lot.
