Hey Guys
I have come up with a really good way to model a corrugated roof and it has worked really well apart from this last issue. The way i modeled the roof was by using a sloped glazing system and then i imported my own corrugated profile into the system. It has come up really well.
The issue i am having now is with the ridge cap. I have modeled the ridge cap by placing a corner mullion on top of ridge. This has worked incredibly well apart from the last bit hanging over the roof and i either need to trim it up somehow or place a new corner piece of mullion on that is shaped like the corner of the roof.
I have attached both a screenshot and the project so you can see and i have also attached my render in lumion so you can see how awesome it has come up in lumion.
Can someone please help with how to clean up the bits that are hanging of the roof.,
@Anonymous wrote:Hey Guys
Considering it is the same topic you previously initiated, why not keep it in the other post where actually several forum members helped/guided you on how to model that roof using the mentioned method which you claim you came up with?
Hey guys would be much appreciated if you can respond here as the previous thread this person referred to has alot of other bits of information that are irrelevant to this. I put it here to make it cleaner and this is more on topic.
@Anonymous wrote:Hey guys would be much appreciated if you can respond here as the previous thread this person referred to has alot of other bits of information that are irrelevant to this. I put it here to make it cleaner and this is more on topic.
@Anonymous
You might as well consider marking a solution on the other post to close it and giving @syman2000 the Credit...fair enough don't you think? From the way it looks reading that post he kinda modeled it all for you
Arent you the peson that sent me this is in a DM. I have reported you again to autodesk stop harassing me please
So the whole conversation and the Screen captures (none of which seem to have given you any clue) and you had no idea what we were talking about all along
and then you figured it all out
I will keep that in mind next time you post a question...saves me lots of trouble
glad your issue got sorted out
