Why does my Revit work so slowly?
It takes 3-4 seconds to see the blue circle between views.
Could this be a Revit issue or maybe my new Zbook?
What "Blue Circles" between Views? What takes "3-4 seconds"? Care to be any less cryptic?
I used to say that my rivet works very slowly and I tried to update it, but to no avail Revit 2020 2020 the same problem and I don’t know what the solution is
Hi @Anonymous
Thank you for the question. Please be sure your computer meets the requirements outlined below;
It could also be due to the file size that you are working with, is it an empty file?
Yes, I have all the requirements and work on all design programs, except for the Revit, it has become very heavy in addition to that the file is not very heavy
Hi @Anonymous
Are you working on wifi, and connecting to a server were the central file is located?
As far as those errors I would try doing a repair, on your Revit to see if that corrects it.
I really am worried because my dependence on designs depends entirely on the revit, I hope you solve my problem and I trust in your capabilities
Hi @Anonymous
I would try hard wiring the computer. Also I would run a repair on your Revit install.
Hi @Anonymous
I am not sure what you are asking. Workers?
Because after this problem, I downloaded Revit 2021 and Revit 2020 together and now they are upright on my device
Which ever version is throwing the error is the one you would need to repair.
Based on the images you posted, there are two external tools (aka add-ins) that you have not installed: Advance Steel Extension for Revit & MEP Fabrication: Part Commands. You need to install each of these components in order to address these errors.
Can you please give me the links to install the tools or how can I install or get them
