I have 12 lights in this small room and none of them are rendering. Why?
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
winstonfoxnelson
817 Aufrufe, 10 Antworten
The bookcase has 3 nested lights in it, two of which are undercabinet lights which I've cranked up the intensity on. All the other lights are stock. I'm at my wit's end. Thanks for your help! Project attached.
10 ANTWORTEN 10
Nachricht 2 von 11
Secttor
als Antwort auf: winstonfoxnelson
Hi @winstonfoxnelson
You've saved your project in an earlier version of Revit, probably 2018 so cannot saw it. Il also depends which settings are used in the render dialog (clouds?) and also to be sure the light-source is not inside a geometry.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Nachricht 3 von 11
winstonfoxnelson
als Antwort auf: Secttor
Yeah it's 2018, sorry about that.
I have a wide variety of lights including floor lamps, ceiling lights, and
wall lights. The render setting are such that it's interior artificial
only, all the lights are on and the dimming setting is set to 1 (no
dimming). I've tried turning the light exposure all the way up, shadows all
the way down, etc. The render shows totally black.
Nachricht 4 von 11
aRcHiTeCt.JM
..... hi
.... what you need to do is to tweak these settings
... and lower the intensity of the cabinet lights
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 5 von 11
winstonfoxnelson
als Antwort auf: aRcHiTeCt.JM
What the heck? This is driving me crazy. I have just done another rendering using the same settings you had, and adjusted to the exact same number you have, clicked "apply", and it's still black. Could it be that there's some other setting within Revit that is incorrect on my end?
Nachricht 6 von 11
aRcHiTeCt.JM
... let's try this:
... go to your plan view
... create a new 3dview and try to render it with the settings I just said before
....let me know....
.... or maybe try moving forward your camera...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 7 von 11
Make sure your camera is not burried inside a wall.
Nachricht 8 von 11
winstonfoxnelson
Somehow, the camera was in the wall, even though in the 3D view it didn't appear to be so. How bizarre! Anyway thanks for your help.
Nachricht 9 von 11
@winstonfoxnelson
Another thing: You need to Share your Light Fixtures that are nested inside your Bookcase Family. If you notice, they aren't even showing up in your Artificial Lights Dialog Box.  But, once shared, they all seem to Render well. I tested one by one.
Nachricht 10 von 11
aRcHiTeCt.JM
... hi @winstonfoxnelson
... that's why I said to move your camera a little forward
.... but your camera wasn't inside of the wall
.... I have rendered without any problem
.... anyway FANTASTIC that you got it
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 11 von 11
572581
als Antwort auf: barthbradley
Thank you this information about sharing lights was exactly what I needed
