I got an Error when using GPU render in revit Vray plugin it's work just fine with cpu renderingsee that yellow text
[Warning] V-Ray: Failed to load bitmap ""
this is a result
I just wonder what I did wrong and does anyone know how to make it right ?
thank you for help
.... you need to go and ask here:
https://forums.chaosgroup.com/
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
The way I read it, VRAY couldn't find or use a particular render appearance image. Do all the materials used in the rendering look correct?
...are you rendering any links?
