About a week ago, after an update to Windows 10, whenever I try to open any project on Revit Architecture 2015, I the spinning circle. I unsistalled and cleaned up my machine on any autodesk products and folders, resinstalled Revit Architect 2015 and still have the same issue. I installed these on another machine, just to test, and I have no problem. Any ideas?
Gelöst! Gehe zur Lösung
Gelöst von emodderman. Gehe zur Lösung
I believe Revit 2015 is not supported on Win10 platforms...
i have revit 2015 in installed in windows 10 and it works fine, try to install latest updates from autodesk and try to uncheck your use hardware acceleration from options and updates your graphics card driver to the latest and see if helps. thanks
@Anonymous
You might also have to run Revit in compatibility mode (right click on revit, and run in compatibility mode)
