in this attached image, I am tying to import an office desk, this is what i get.
also, how can I import from BIMObject with the same materials and colors ?
check the properties of the family in the family editor.
use the view cube to rotate the desk to see what is behind orto the left side of your desk family
look at plan views in the family editor to see how it is built.
use the 4 blue squares icon to check properties.
each BIM Object may have different properties based on Materials and colors, so there is no quarantee your result is consistent.
Hi @Anonymous
Welcome to the community!
Can you share the BIMObject you've downloaded?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
