I'd like my elevation marks to label alphabetically instead of with numbers. Is this possible to set up automatically in Revit? If you look at the screenshot I'd like to change the number #1 to 'A'
#2 to 'B' and so on. Thanks!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Manually, yes. Automatically, no. With Dynamo maybe.
You can create a view schedule, filter to show only elevation views, sort by number, unitemize, then replace 1 2 3... with A B C...
@Anonymous
Not in Revit. However, it is easily doable with dynamo and several plugins/Addins do offer that option too example: check the one from Evolve ...it is currently a beta free version you can download from their site
Renumber Views In Revit EvolveLAB Add-in Update
@Anonymous
Dynamo is a standard tool to work with. Solar to lisp and autolisps in Autocad.
For now these are your only options. You can post an Idea on the Revit Ideas forum
