Hello everyone,
This happened to me for a while but now i cant bear it anymore. I could not upate the newest version of any Autodesk product.
I have tried update by Autodeck Decktop App but Red notice told me " An unexpected error has occurred. Server is unable to process this request. Please try again later" as the attechment screen-captured. I also download the uppate version by Brower but it turned " Install Failed. The uptate could not install because the expected product could not be located on your computer".
I am running with my project but this problem is stop me down. Sr for my any mistake English.
I am very please if you guys can help
Solved by Viveka_CD. Go to Solution.
If is is the case maybe you need to tried download directly and then install.Go to Manage Products and then go to updates products https://manage.autodesk.com
Hi @Anonymous
Sorry to hear that you are having issues.
Please try the steps below and let me know if it helps resolve your issue:
To troubleshoot the issue, do the following:
If the issue persists do the following:
I look forward to hearing from you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
It work!!!
Thanks you very much for give me very detail instruction.
You are angel to me. Wish the best for you.
Hi @Anonymous
I'm happy to hear that on Thursday morning!
Glad to know that this worked for you.
Let me know if you have additional questions!
Viveka CD
