i cant modify the stair riser height, i've tried doing that with different types of stairs
The riser height is automatically calculated based on the overall height of the stair AND the Desired number of risers. Change one or both of these value then the riser height will change.
Hi @giacomo_darasmo
Thanks a lot for posting your question to the forums! Has the solution suggested by @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
