i attached here my revit project file, and the 3d dwg file i need to import , but it is never be imported and i dont know why
can anybody help ?
Gelöst! Gehe zur Lösung
Gelöst von dzanta. Gehe zur Lösung
the 3d cad file looks like a sign or logo of some sort. If you are trying to make a Revit family based upon that cad file, start a new generic model revit family and go to the default 3d view, then insert the cad file. once inserted, modify it to use revit content or leave as it. Save it as a Revit family somewhere and then load it into your project to use.
(EEJan17...for contest)
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
but, why cant i import it in the main project file, as i did with this file i attached now.
the file which i am attaching now, is also inserted in the revit project file, i just dragged it into the file and everything went perfect
please advise
Try to convert your mesh to a solid or surface in Autocad before importing it in Revit.
You also could just (re)model it in a Revit family
Louis
Please mention Revit version, especially when uploading Revit files.
you can import the 3d cad file into your project directly if you want...just ensure the current view is the default 3d view
yes, i had to do so, as i still cant insert the logo directly to the file project. i believe that there is a problem in the cad file
I opened your cad file...it is a mesh. I exploded it to turn them into 3d surfaces. I imported them into a revit family (generic model). now you can load them into your project..
see attachments.
