Hi
I have all the necassery files for the family files. But they are rft. files. When ı click load family it allows me to load just rfa. and adsk. files
I cannot solve this problem.
An RFT is a Revit Family Template. The RFT serves as a building block, containing the information that you need to start creating the family and that Revit needs to place the family in projects.
As @barthbradley points out the Revit Family Template can't be loaded, it is a blank Family Template, your Libraries should be located here, C:\ProgramData\Autodesk\RVT 2019\Libraries
It is already located there. Butstill not working. I face the same problem
Can you restate your issue then? Maybe we misunderstood you. Walk us through what you are trying to do, step by step.
This is the steps while i am tryin to open family files when I wanna add new windows or doors or etc.
part 2
But ı already hhave the files
part 2
As we have explained, you cannot and do not load rft's into Projects. Those are Templates used to create Families from. You want to load rfa's. Those are the actual loadable Families.
Ok. Now ıunderstood what my mistake is. My Library is actually empty. I have to download this firstly.
Thank you for all ![]()
Revit is telling you exactly what to do. You're in an operation that is requiring you to load a specific category of family. Get out of that operation and use "Load Family" , or open the family directly and use "Load into Project" in the family.
