I CANNOT INSTALL REVIT 2016, WHY?
Everytime I try to install Revit 2016 version, I can't. The program is downloaded and start installing, but after 2 hours, It says "Failed".
I could install the 2017 version, but the Librery Contents got failed too, and I tried to reinstall It, unsuccesfully.
GHASEM_ARIYANI
hi
in the control panel > unistall C++ 2010 and then install Revit 2016
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
