I can't stop oundation finishings at the wall
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
457 Aufrufe, 5 Antworten
I am trying to create a foundation but I don't need the finishing layers on the outside of the basement wall. How can I stop them going out of the wall when I extend the foundation slab?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Is it a slab?  Just edit its boundary and align with the wall structure.
Nachricht 3 von 6
Is it a Structural Foundation Wall? Adjust the wall's Eccentricity (under Wall's Instance Properties).
Nachricht 4 von 6
Alan.johnson1970
Select the floor/slab and on the view tab use CUT PROFILE
Select the layers in the floor/slab you want to edit and draw a new end point for each finish layer. (shown in red)
AJ.
Nachricht 5 von 6
Kimtaurus
You could create 2 floors: one structural and one for the floor finish.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 6 von 6
als Antwort auf: Alan.johnson1970
That's what I'm looking for. Thank you!
