Hi All, I have grid lines in elevations and section but I can't see them in the plan.
I appreciate if you can help me.
Thank you,
Amir
I think you stretched the 3D extent of the grids to above the building based on the picture of your section. To fix it, go back to the section, select a grid and stretch its 3d extent down to below the lowest Level, or right click on it and maximize 3D extent.
And remember only stretch 2D extent of grids/levels if you don't want it to affect all other views.
https://cadcamengineering.net/3d-and-2d-datum-extents-revit-architechture/
