I Can't paste lines on workplace exactly
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
662 Aufrufe, 7 Antworten
Dears ,
I draw lines on elevation view , so when i copy lines and put it in generic model for make extrusion the lines not paste on work place exactly?
you can see the image attached
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: Anonymous
can share your family. thanks
Nachricht 3 von 8
als Antwort auf: ennujozlagam
what you mean Family?
i am using default revit family
Nachricht 4 von 8
ennujozlagam
@Anonymous
you wrote
so when i copy lines and put it in generic model for make extrusion the lines?
so what is this?
it look like you are in 3D mode, have you try go to elevation view and paste there or plan view? thanks
Nachricht 5 von 8
Kindly,
I drew the lines on the elevation view and then copied and paste it into the generic model ( every steps on elevation view)
But when i put lines on workplace of generic model , I find it completely away from the surface of workplace ( approx. 60cm on Z axis )
My question is how can i to move this lines on workplace ?
Thanks alot for your responding
Nachricht 6 von 8
ennujozlagam
@Anonymous hello, you can go to section or elevation view > modify > use align (AL) to move the objects. thanks
Nachricht 7 von 8
chrisplyler
1. Are they Model Lines or Detail lines?
2. A Generic Model is a Revit family category. That is why you have confused us.
Nachricht 8 von 8
Dears ,
I got the solution for my issue :
before copy lines from elevation i select lines
1- After selection am going to edit workplace.
2- Piking  on level I'll work on it .
3- Copy and paste lines to generic model .
4- Finally am working on level work place .
Thanks to your responding , and am sorry for any confusing .
