I Can't miter steel
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
ERWIN-S
482 Aufrufe, 2 Antworten
I Can't miter steel
How to miter this steel or structure beam, please see the attach video. Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
Lachlan-JWP
als Antwort auf: ERWIN-S
As the error says, the shapes of the beams are too different to use the mitre command. You can use a reference plane drawn on the centreline of the larger beams to trim the ends of the smaller beams.
Nachricht 3 von 3
ennujozlagam
here. thanks
