I am trying to lock the shelves for it changes the width together with the panel which is behind. But when i am trying to put a formula, revit says that constrains must be removed.
What's going on?
I am sending the family attached.
Thanks!
Right now the shelves change their Width along with the panel behind it. Did you want them not to change?
Hi @uoliveira
Are the constraints related to linear dimension or alignment?
You have a void casework (extrusion) hidden in your model, can you remove that and try again? Can you clarify what formula you have tried, and give a screen shot of the error (please expand the errors).
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @uoliveira
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Viveka CD
