I can't load structural column in revit 2017
I can't load structural column in revit 2017.Revit and load column are the same version.One week ago,I can make load column in this way.Please,help me seniors.IMG_20210209_171551.jpg
mauricio_mssf
Maybe you are loading an element that is not a Structural Columns, or the fact that you have the Standed Coluns selected.
Check correctly the category of the family you are trying to load, and I advise you to insert it through the process: Panel Insert -> Load Family - Look to the family you want on your folder.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Thanks,I got it.
Thanks,I got it.
