I can't fix this problem
c_bovo
Message 1 of 16
c_bovo
Hello everyone, i have a problem with a front elevation in my project, one window appears like this. Can anyone help please? I don't understand how it happens
Replies (15)
Message 2 of 16
jay_colc
Those look like Door swing/opening lines.
Can you turn them off in Visibility Settings?
or in the Door/Window Family Edit the Visibility settings for the Symbolic lines
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 16
c_bovo
i'm sorry but i probably didn't explain in the right way. I meant that there's like a red texture instead of a glass texture and i don't understand why. It's an imported family so the material should be right. I have this problem only on "front elevation" view
Message 4 of 16
jay_colc
Is there a Wall close behind it with a Red Finish?
Also check the materials in the Door Family as it could be the issue or have another item attached such as a built-in blind/shade
Jay Colcombe
Message 5 of 16
ennujozlagam
you need to share your family so we can take a look
Message 6 of 16
Simon_Weel
Looks like there's a wall behind the window. Use Join to join that wall to the wall in front. If that doesn't work, you probably created a Void in the Windows Family but it's not deep enough to cut that red wall.
Message 7 of 16
c_bovo
Thank you to everyone but there's no walls behind. im gonna share the window's family. Unfortunately i have this problem in other front elevations
Message 8 of 16
jay_colc
Replace with another standard Door/Window does this work?
Loading into a Standard OOTB Revit Wall build-up it works as expected
So try a few things;
Change the Window to a Standard Window - does that work?
Change the Wall to a Standard Wall - does that work?
If both of the above are YES - I would suggest due to your wall build-up it is not cutting through the whole of the Wall and layers
Jay Colcombe
Message 9 of 16
c_bovo
Itried changing the wall with a generic one and i also changed the window. This is the result
Message 10 of 16
lucdoucet_msdl
@c_bovo
Rather than changing the window family to another type, try and temporarily hide the window with the Revit Temporary Hide/Isolate tool  (Eyeglasses). This will retain the opening but hide the window family establishing whether the red element is part of the window or behind the window. With the window hidden and the red material still visible you can tag the revit element with a material tag to help identify the offending family.
Ex.
Another test would be to reduce the elevation view depth to just inside the interior thickness of the wall to see if the red disappears.
As @jay_colc mentionned, the second wall is still a possibility if the wall is masked by visibility parametes in other all other views but the elevation view. If you create a new 3D view, open all workgroups, make all types visible, and set to realistic, do you also see the red material?
Without access to the project file, its all detective work.
Hope this helps,
-luc
Message 11 of 16
c_bovo
Grazie per la risposta, ma non riesco ancora a risolvere il problema. Ho provato con le due opzioni che mi hai inviato.
Message 12 of 16
jay_colc
Save your model under a new name and delete everything apart from the Wall and Window and share - this is the simplest way and you do not need to share the whole project to protect your information.
Jay Colcombe
Message 13 of 16
c_bovo
Here's the file just with that wall and the windows
Message 14 of 16
jay_colc
There is definitely an issue with the Families and you model, inserting a new default window i got the same for the Realistic Visual Style
But also for the Family the Glass Extrusion does not appear to be correct?
Compared to the other Window?
Jay Colcombe
Message 15 of 16
jay_colc
This is the fix
Windows and Curtain walls are transparent in elevation view in Realistic mode in Revit 2021 and late...
Jay Colcombe
Message 16 of 16
lucdoucet_msdl
@jay_colc
Good catch.
As it may not be obvious to future readers of this discussion thread, the problem and solution seems to be:
  • In the initial model, the glazed parts of the some of the windows were opaque while other families the glazed parts were transparent in realistic views;
  • The red materiel visible in the transparent windows were on walls located behind the openings (as can be seen with the shadows cast by the opaque frames);
  • The solution was to change the "transparency" parameter of window family to read as "opaque" with the workaround explained in the link on your post.
-luc
