i Can't Edit Genric Model.
5 ANTWORTEN 5
Nachricht 1 von 6
jlogesh1992
363 Aufrufe, 5 Antworten
Hi Sir/Mam,
I am going to edit the genric model in project the revit file will closed,
if I Copy the Genric model & Paste in new project it is Editing.
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: jlogesh1992
@jlogesh1992
The Family appears to be in a Group...Usually this shouldn't be an issue and you should be able to edit it even if! but it's worth a try to edit Group first then try to edit Family. Did you try to exclude from Group then use temp Isolate then edit (Just to see if the issue isn#t caused by the Group
Otherwise, in the Project browser locate that Family > right click and edit it in Family Editor. Then load it back into the Project and overwrite the existing.
If the issue isn't resolved...try to Close and reopen the file...on the open Dialoge choose Audit Option.
Nachricht 3 von 6
jlogesh1992
als Antwort auf: RDAOU
This Is Single Genric Model In the Revit File Not In Group,
I Try to edit the genric Model in project browser also (Otherwise, in the Project browser locate that Family > right click and edit it in Family Editor. Then load it back into the Project and overwrite the existing.) it's not working
After This Process revit File Will be closed.
Nachricht 4 von 6
RDAOU
@jlogesh1992
Did you try to Audit the file?
If you can provide the following, one may be able to help you. With nothing in Hand I am afraid I cannot predict what the cause of the error is.
  1. Can you upload the log file?
  2. Can you upload the .rvt file so one may have a look at it?
Nachricht 5 von 6
jlogesh1992
Here not possible to upload the file. :enttäuschtes_Gesicht:
Nachricht 6 von 6
Have you used the new Screencast add in for Revit? It's incredible! It's free, install the add in, record step by step the process in which you are encountering the problem, then upload to us as a reply! That way we can see exactly what steps you are taking and exactly where the error occurs :leicht_lächelndes_Gesicht:
