I can't change the height of the levels in revit 2025
jhordam.pamplona236F3ZC
I tried everything to change the height of the levels in my project, but nothing worked, I even tried creating another level and changing the level reference of the elements and it still didn't work, I'm facing this bug among others in revit 2025.
RDAOU
@jhordam.pamplona236F3ZC
Is it a workshared model and they are on a Non-Editable workset locked by your Project Admin?
No, it's a local file saved on my computer.
But now this problem of not being able to edit the height of levels isn't even the biggest problem, there are several other bugs that don't make sense, I'm simply not being able to delete some elements, and model changes in place aren't being saved. After this project I will no longer be using Revit 2025, it is too risky.
RDAOU
Its hard to tell what you are experiencing if one does not have access to your model...Are you able to change the level elevations if you enter the values in the properties panel instead on the level datum itself? Select the Level and change the Elevation Instance parameter on the PP
Not being able to delete elements could have many reasons....The are in design options, they are pinned ....etc
it is also possible that the levels are constrained by other elements which are level based. You might also want to look out for those as well.
Workshared models generate local file too. Are you collaborating with others or you are working on a literally local file not workshared and has no worksets at all.?
I could send my file to you, without any problem.
I tried to change the height of the levels in several ways, the only way I could move them was by deleting all elements related to the level.
They are unfixed elements and not design options.
I'm working on a local file without sharing, and this problem is present in several files made in Revit 2025, even in files made by others that were sent to me.
Aayazaki
Community Visitor
Community Visitor
Have you find a solution to edit the levels height, same problem here!!
