I can not activate the student version Revit
1 error at the first start
2 after confirmation of the error
3 then i discovered product information and pressed to activate
4 I pressed to activate
5 I pressed Next
6 and again error
7 so I chose ``Try`` version, and the present license expires in 30 days
8 This message that I got with a serial number
See in the attached file
RDAOU
Hello @Anonymous
Did you use the Serial Number and Product Key provided via email from Autodesk Education Community? If you didn't you will end up ultimately with the 30 days trial.
If you have got the Serial# and Key...Try first to Update the Serial # with the one issued by Education Community before you activate
You may attach .png or .jpg image of the error to your reply (I can not download zip files
if this Helps. Accept as Solution (Kudos are also appreciated)
​Yes, i used the Serial Number and Product Key provided via email from Autodesk Education Community. Last screenshot is with this key
Here is link to this screenshots
https://drive.google.com/folderview?id=0B5MJhJ0ZXhtQX3I2R0xwRXVfMkE&usp=sharing
RDAOU
Hello @Anonymous
You should have received a second email after you installed and started Revit and signed in to your ID (upper right corner) in revit
Can you please do that and double check for an email with Activation Code
PS: you can remove those images from Google Drive...
I signed in my account, and i had no any email for couple hours.
RDAOU
Hello @Anonymous
I am assuming you checked the Junk mail Folder and it is also not there?
I suggest you submit a request for assistance to the education community directly here and state in it
1. Downloaded Revit Student Version and after installation it is only offering a 30 days trial.
2. Did not receive the activation code so activate Student License and start the 3 years period.
Do not complicate the discription more otherwise they might go off topic
If the above helps; please mark this reply Accept as Solution
