I am stuck just getting started
2 REPLIES 2
233 Views, 2 Replies
None of the templates load when I am starting Revit. I get the message "The file path you have specified for the default family templates is invalid. To change the default file path, from the Application menu select Options, and then the File Locations tab". Where is the applications menu?
2 REPLIES 2
artejon
It's under 'R' at upper left corner.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
mpeperkamp
Hi @Anonymous,
I have make a screenshot for you:
The template can you found in the following map:
C:\ProgramData\Autodesk\RVT 2017\Templates
If there no template are in this map you have to instal them again.
The following link while tell you how to do this.
I hope that you enjoying working white Revit2017.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Forma Design Contest
