I have HVAC Zones / Spaces showing on my architectural plans and sections. They are from a linked Mechanical model and I cannot figure out how to turn off their visibility. The Autodesk Revit 2019 Help menu shows: VG > Model Categories > HVAC Zones, and VG > Model Categories > Spaces, but I do not see either in the list (see attached image). Any ideas on how I can turn them off?
Windows 10, Revit 2019 file on BIM360, view template applied to views
Gelöst! Gehe zur Lösung
Your Visibility/Graphics menu is quite a bit more sparse than mine. Have a look at how many more categories my desktop version of Revit shows:
Is the version you're using on BIM360 a light version? Or is the linked file from a light version of Revit? (I don't know if this second question would matter if you're using full-Revit, I've never used anything besides the complete version of Revit.)
I figured out that I had the VG model categories filtered to only show the Architectural Categories. You have yours showing all possible categories, so your list is much longer than mine. Adding Mechanical to the filter list reveals the HVAC Zones and Spaces categories.
