HUGE Worksharing issue
LisaDrago
Advisor Advisor
LisaDrago
So - got a HUGE worksharing issue - It isn't working!!!
I have a client with a project that worksharing has been enabled. The central file has been established along with their local files. There are just 2 people working on the project. Person "A" gets in and works - Person "B" gets in and works on the same object as A and gets no warning that the elements are being edited by someone else. B saves to central then A saves to central and get a warning that revit cannot reconcile the differences between the local and central.
What is up with this??? I have never seen this before. Both users have the latest build with service pack 2 installed.
Has anyone hit this before?
Please help!!!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
rosskirby
I've seen this happen a couple of times before.  Somehow both users were using the same username.  That's why the central file wasn't seeing the two separate local files as "different".  Go to the Options on each user's computer and make sure they aren't using the same username.  If they are, then correct whichever one is wrong.  If that's not it, then I have no idea...
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
LisaDrago
No WAY!!!Robot surprised
I can't believe I didn't think of that!
I am having them try it right now and will let you know.
Thank you so much for your help.
LD
rosskirby
Hope that works for you.
I'm still not entirely sure how it happens.  Maybe if each user had logged onto the same computer at one point...?
Ross Kirby
Principal
Dynamik Design
LisaDrago
That totally fixed it.
Thank you for your help!
LD
rosskirby
Glad I could help.
Ross Kirby
Principal
Dynamik Design
