I want to repair an STL I made in Revit so that I can 3d print it but it seems too large for fusion 360 to take/do a worthwhile job on anyways any thoughts. Roughly 4 GB with around 14.5 million triangles? is there a better way to do this starting in Revit perhaps?
If the roughly 20 cm dimension is the size you want to 3d print then your model has way too much details.
its not I will scale it up to about 200 cm but I am not sure how to get the windows to be solid or the base to not have a hole in the bottom.
