How to visualize the ground patch just till the line window of the section
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1123 Aufrufe, 8 Antworten
Hi to everyone I created the ground i just need to visualize the ground patch just more below...till the line window of the section.
How should I do it?
Thank you
Gio.
8 ANTWORTEN 8
Nachricht 2 von 9
Ilic.Andrej
als Antwort auf: Anonymous
How did you create "the ground"?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 9
als Antwort auf: Ilic.Andrej
surface topography
Nachricht 4 von 9
Cut the Toposurface in the View.
Nachricht 5 von 9
Nachricht 6 von 9
SteveKStafford
The depth of the cut fill pattern (toposurface) is defined in Site Settings > Elevation of poche base
Steve Stafford
Nachricht 7 von 9
als Antwort auf: SteveKStafford
Good reading skills @SteveKStafford.  Better than mine, for sure. I missed the whole "I need to visualize the ground patch just more below" part of the question.
....I blame Evelyn Wood. :zwinkerndes_Gesicht:
Nachricht 8 von 9
syman2000
Go to the Model Site setting and change the poche depth
Nachricht 9 von 9
FacebookGroupMember
The depth of the cut fill pattern (toposurface) is defined in Site Settings Elevation of poche base
Source Message URL: https://forums.autodesk.com/t5/revit-architecture-forum/how-to-visualize-the-ground-patch-just-till-...
