How to use the parameter that data type is Image in the family?
jonahHUSCT
jonahHUSCT
I’m a newbie to starting Revit, i’m creating a family have an image and a title. For the title, i use Create > Label to set the parameter and place I want. But I cannot do that with the image. How can I set the parameter and place an image in the family?Pasted Graphic 1 copy.png
ralphdenhaan
You can add them by clicking on the dots on the right of prameter Value.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
denis_borodin
ralphdenhaan is right, but you can use image parameter type only for schedules, something like that. If you want to put in into family and then see it into project, you should use materials (check this topic)
Denis Borodin, BIM Manager. LinkedIn
constantin.stroescu
I'll do it as follows:
  • create a Detail Item Family that contains a Inserted Bitmap
  • Export the previously created Family into DWG
  • create a new Detail Item and insert the DWG into it
  • load the new Family into Project
https://www.youtube.com/watch?v=z6fVgqGwPwI
Constantin Stroescu
jonahHUSCT
Thanks! But I want to pass a path of the image from a project into the family and then show up :((
jonahHUSCT
Thanks, I will research the "materials". But is it possible if I pass a path of the images from a project?
ralphdenhaan
You can also try what @constantin.stroescu mentioned.
