How to use revit to link topography
4 ANTWORTEN 4
Nachricht 1 von 5
251 Aufrufe, 4 Antworten
Hi.. I've just downloaded and installed Autodesk Desktop Connector as instructed in revit. But when I click Link Topography the screen message always ask me to installed, setup, and run it even though it has been running. How to activate or use Link Topography? Please advice me. thanks
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Maybe it's off-line.
Scheduled Down Time: We will be performing a maintenance update from 8:30-10:30 pm PT on Friday, September 20. Some features and functionality will be unavailable during this time, but no action is required.
Nachricht 3 von 5
loboarch
Are you logged in with your Autodesk ID?  You would see that message if Desktop Connector is installed and running but you are not logged in with an Autodesk ID with the right permissions.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 4 von 5
als Antwort auf: loboarch
Hi...
Im sure that already logged in properly bcoz it has been showing my account name in the autodesk connector desktop . then, what should I do if it is already login as seen as below picture ?
Nachricht 5 von 5
als Antwort auf: barthbradley
Hi...
it is still in on line condition as seen as below :
